grafanaenterprise10.2.2 for windows - What are you trying to achieve?
i am trying to prepare a grafana dashboard with gatling - How are you trying to achieve it?
- i have installed Grafana enterprise 10.2.2
- launch the localhost:3000
3)login as admin
4)Downloaded frontline-grafana-bundle-1.16.5-bundle
5)allow_loading_unsigned_plugins = frontline set in defaults.ini file - restarted the grafana server
- trying to add gatling enterprise from gatling server by configuration - > add a data source - > gatling enterprise (unsigned) but configuration is missing
What happened?
trying to add gatling enterprise from gatling server by configuration - > add a data source - > gatling enterprise (unsigned) but configuration is missing -
i should be able to add by configuration - > add a data source - > gatling enterprise (unsigned) -
Gatling Beginner Tutorial 14 | Show Gatling Results On Grafana Dashboard | - YouTube
