Introduction:
Pie charts are a popular and effective way to visualize data, offering a clear and concise representation of the proportional distribution of categories within a dataset. The Business Charts Plugin provides a robust and user-friendly toolset for creating visually appealing and informative pie charts, making it easier for businesses to interpret and communicate their data insights.
You can follow these steps to customize all labels as you want
Step 1. Create table with your desired fields and insert your desired data:
Step 2. Install the business charts plugin
Step 3. Create new grafana dashboard and add visualization
Step 4. Click on add visualization and select your desired datasource
Step 5. Search for business charts panel type and click on it
Step 6. Write select query for selecting your desired data
Step 7. Now go to the function section and paste this JSON code to this section
return {
dataset: {
source: context.editor.dataset.source,
series: [
type: βpieβ,
bottom: β50β,
radius: β70%β,
emphasis: {
itemStyle: {
shadowBlur: 10,
shadowOffsetX: 0,
shadowColor: βrgba(0, 0, 0, 0.5)β
label: {
formatter: function (params) {
var label = ;
const FIRST_ROW_INDEX = 0; // Define a constant for the first row index
// Add dynamic fields from the dataset
var additionalFields = context.editor.dataset.source[FIRST_ROW_INDEX]; // Get column names from the first row
var firstlable = additionalFields[0]
// Add the first value
label.push('{a|' + firstlable.substring(2) + '}' + ' : ' + params.value[0].slice(0, -8));
// Add subsequent values
for (var i = 1; i < params.value.length; i++) {
var fieldName = additionalFields[i];
label.push('{a|' + fieldName.substring(2) + '}' + ' : ' + (params.value[i] || '-'));
return label.join('\n');
backgroundColor: '#fff',
borderColor: '#8C8D8E',
borderWidth: 1,
borderRadius: 4,
rich: {
a: {
color: '#000',
lineHeight: 22,
align: 'left',
fontWeight: 'bold'
hr: {
borderColor: '#000',
width: '100%',
borderWidth: 1,
height: '100px'
b: {
color: '#000',
width: '100%',
padding: [6, 4] // Example padding
per: {
color: '#000',
padding: [5, 3],
fontWeight: 'bold' // Example padding
c: {
color: '#000',
padding: [5, 3],
tooltip: {
trigger: 'item',
formatter: '{a} <br/>{b}: {c} ({d}%)' // Tooltip format including percentage
legend: {
orient: 'vertical',
left: 'right',
top: 'center',
align: 'left',
textStyle: {
color: '#000'
var padding = ' '; // Adjust the padding as needed
var data = series[0].data;
for (var i = 0; i < data.length; i++) {
if (data[i].params === params) {
return padding + params + ' (' + data[1].percent.toFixed(2) + '%)';
return padding + params;
Step 8. Now go to the Visual editor section and add your fields but make sure following points while adding these fields:
- The first field will be the label value field
- The second field will be the pie chart slice value
- The values after second field will started listing below the tooltip values
Step 9. Click on save and then apply
Final Outcome:
lochanie1987
If you need any assistance, please feel free to contact me.
Shanker Agarwal
(Grafana Architect)
shanker.agarwal@dataabsolute.com
