How to sign in local grafana?
I can’t log in local grafana.
  • What happened?
  • Did you follow any online instructions? If so, what is the URL? URL is 5.9.87.218:30080
You try admin/admin?
SAME ISSUE with me GREFANA OSS removed, reinstalled, DID NOT ASK ME TO SET UP USERNAME PASSWORD, can get to :3000 login screen but does not accept admin/admin.
says wrong password and DOES NOT send me password reset link in email either
Hello @kingaimaster94 please check the grafana log
which os you are using
windows grafana log path : C:\Program Files\GrafanaLabs\grafana\data\log
Linux : /var/log/grafana/grafana.log
if password problem then reset the password and restart the service.
