I want multiple row of data to be displayed in my dashboard but its only showing 5 rows at a time, also checking from the query inspector i have verified that data is retrieving. I am using boom panel view.
welcome to the
forum, @umer09
Is there a reason you do not want to use the built-in Table panel?
Otherwise, I think your best bet, since this is a 3rd party plugin, is to make an issue in the plugin’s repo:
The reason why are using boom table is because it allow us to convert rows in to columns based on specific patterns.
However i don’t thick table view panel provides similar functionalities as our basic requirement that’s why we need to use boom table.
Do you know other visualization/ table views/ plugins that help us achieve similar functionalities,please share
your input will be highly appreciated.
