When using pie chart plugin and display the legend, its rows, or rather every other row is shaded. See the picture below. Is there a way to achieve the same thing pie chart legend does out of the box with table plugin, or rather its rows? Thanks.
Unfortunately, the built-in Table panel doesn’t support striped rows. I’d recommend that you have a look at the the Datatable panel plugin, which does offer support for striped rows.
Thanks for the tip, Marcus - an interesting plugin. It does have striped rows, tho they are not visible or rather you can’t distinguish that in Dark mode. On the top of which (and that is a show stopper), it does not pass variables in the URL when used w/ field. (none of which has to do with Grafana, just saying).
