This results-cache pod has two containers memcached and exporter.
By default, I have
This is because here,
resultsCache:
# -- Amount of memory allocated to results-cache for object storage (in MB).
allocatedMemory: 1024
# -- Resource requests and limits for the results-cache
# By default a safe memory limit will be requested based on allocatedMemory value (floor (* 1.2 allocatedMemory)).
resources: null
The memory is calculated based on allocatedMemory which is why got that 1953125Ki.
If I set
resultsCache:
resources:
requests:
cpu: 100m
memory: 128Mi
limits:
cpu: 200m
memory: 256Mi
I can see
memcached container in results-cache pod, the resource limit has been applied.
However, I am still not sure how to set the rest of exporter container CPU and memory resource limit.
Any guide would be appreciate, thanks! ![]()
