I’m following the guide Install the monolithic Helm chart | Grafana Loki documentation to install loki in my k8s cluster:
deploymentMode: SingleBinary
loki:
commonConfig:
replication_factor: 1
storage:
type: 'filesystem'
schemaConfig:
configs:
store: tsdb
index:
prefix: loki_index_
period: 24h
object_store: filesystem # we're storing on filesystem so there's no real persistence here.
schema: v13
singleBinary:
replicas: 1
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
The installation works “fine” but if I execute kubectl describe pod loki-chunks-cache-0. I see the following error in the loki-chunks-cache-0:
Warning FailedScheduling 59s (x297 over 24h) default-scheduler 0/2 nodes are available: 1 Too many pods, 2 Insufficient memory. preemption: 0/2 nodes are
And the following resource requests:
memcached:
Image: memcached:1.6.23-alpine
Port: 11211/TCP
Host Port: 0/TCP
Args:
-m 8192
--extended=modern,track_sizes
-I 5m
-c 16384
-v
-u 11211
Limits:
memory: 9830Mi
Requests:
cpu: 500m
memory: 9830Mi
I understand that the problem is that I’ve not enough memory in my k8s cluster. But is there anyway that I can indicate in my yaml the limits/requests for the memcached to reduce these needs or even disable this cache?
