I am running Grafana Loki in K8s ENV as a single pod and fetching data saved in the same using grafana dashboard.
Sometimes when I check for old data. Say one day before data, it doesen’t show me any logs/data. ( Gets a messages like: No logs/Data found).
When I try restarting the pod( Deleting a recreating the pod) and check again for the same date, I can see data populating without any issues.
Any Idea, Why this is happening and Is there any workaround for this.
Please help.
Thank you for responding, Tonyswumac.
Here is the Loki config.
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
limits_config:
allow_structured_metadata: true
#EXTRA ADDED
ingestion_rate_strategy: local # Default: global
max_global_streams_per_user: 0
max_query_length: 0 # Default: 721h
max_query_parallelism: 32 # Old Default: 14
max_streams_per_user: 0 # Old Default: 10000
ruler:
alertmanager_url: http://localhost:9093
By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
I couldn’t find any specific logs.. Will check and post if I could find any when I face the same issue again.
Does the config looks fine…? Is there any thing to be changed in the config file to mitigate same issue from happening again…? Thanks
I updated Loki Version to latest version: 2.9.3 (Latest release as on 26-DEC-2023). Now waiting to see how it behaves now. Between any help or suggestions will be helpful.
