Loki Monolithic Memory Consumption
Hello Loki Team,
I am deploying Loki in monolithic mode and sending logs with Fluent Bit. One thing that’s catching my attention is the memory consumption. Just by deploying Loki, the memory usage gradually increases until it stabilizes at around 1.5GB. I’m not sure if this level of consumption is normal??
Furthermore, when I perform a query like {namespace="kong"} | json | line_format "{{.message}}", the memory usage can spike up to 4GB or more. I understand that this is not an efficient query, but I’m wondering if a different deployment mode could reduce this consumption.
Below is my values.yaml:
loki:
  auth_enabled: false
  commonConfig:
    replication_factor: 1
  storage:
    type: 'filesystem'
  limits_config:
    reject_old_samples: true
    max_cache_freshness_per_query: 10m
    split_queries_by_interval: 24h
    max_query_parallelism: 100
    retention_period: 20m
  query_scheduler:
    max_outstanding_requests_per_tenant: 100
  frontend:
    max_outstanding_per_tenant: 2048
  compactor:
    retention_enabled: true
    retention_delete_delay: 10m
singleBinary:
  replicas: 1
  resources:
    limits:
      memory: 4Gi
    requests:
      memory: 100Mi
  persistence:
    storageClass: gp2
monitoring:
  # Self monitoring determines whether Loki should scrape its own logs.
  # This feature currently relies on the Grafana Agent Operator being installed,
  # which is installed by default using the grafana-agent-operator sub-chart.
  # It will create custom resources for GrafanaAgent, LogsInstance, and PodLogs to configure
  # scrape configs to scrape its own logs with the labels expected by the included dashboards.
  selfMonitoring:
    enabled: false
    grafanaAgent:
      installOperator: false
  # The Loki canary pushes logs to and queries from this loki installation to test
  # that it's working correctly
  lokiCanary:
    enabled: false
gateway:
  enabled: false
# -- Section for configuring optional Helm test
test:
  enabled: false
I personally don’t run Loki in monolithic mode, but 4GB of memory consumption seems to be normal (depending on your log volume, of course).
If you anticipate taking in any amount of real log volume I’d recommend you to look into simple scalable mode.
