How to set clickable links in Canvas panel elements
Steps to apply Links on elements
Step 1 . Go to transformation tab and add new transformation from calculation
Step 2. Now select reduce row and select last in calculation and enter alias name
Step 3 . Now go to field override and add override with name
Step 4 . Now select the field which we have created from transformation
Step 5 . Now copy the link you want to copy
Step 6 . Now add field override property in canvas dashboard Data Links > Data Links and enter link and click on save make sure you have check open in new tab button
Step 7 . Now go to the add item and add Metric value and map to it’s location
Step 8 . Now set text value to from fixed to field and select the field which we have created from transformation
Set
Text size value to 0
Set colour to transparent
Background to transparent
Final Outcome
Make sure you have disable inline editing in canvas dropdown section and if you want to edit you can again enable inline editing and after making changes you can also disable it.
