Grafana 9.2
Ubuntu 20.04
- What are you trying to achieve?
I have a bar chart that currently looks like this:
I would like to overwrite the time-label on the x-axis, so that they are of format DD.MM..
I am unable to figure out how to do this.
This is the query that is used to obtain the plot data:
SELECT SUM("difference")
FROM (
SELECT DIFFERENCE(MAX("aenergy_total")) AS "difference"
FROM "pm_shelly"
WHERE time > now() - 6d
AND custom_id =~ /^shelly_112|shelly_113|shelly_114$/
GROUP BY time(1d), "custom_id"
tz('Europe/Zurich')
GROUP BY time(1d)
tz('Europe/Zurich')
