I am creating the pie chart out of log level in my application logs. I am getting output but there is empty field also coming in that how can I remove that field.
Any help would be appreciated.
Welcome @lalchandrajak05
Maybe using transformation Filter by query might do the trick
Thanks for the reply but still the same tried applying the transformation filter by query.
Thanks @yosiasz i was able to solve the issue with above transformation filter!
