How to remove "count" from showing up as part of the legend
    • 9.1.1
    • Display results in legend
    • Now sure how to say this without sounding snarky, but, following the normal process to build a time series panel that displays results in the legend
  • What happened?
    • The results show but it also displays count before each result, see screenshot. This only happened after our upgrade to Grafana 9
    • The legend should not display count as part of the result.
    • Cannot due to sensitive data.
    • No erros
    • No instructions followed, just worked on the panel like I normally do for time series data.
For additional context, this is based off a postgres query that when tested in DataGrip or pgAdmin does not display the results with count as part of them, this is only happening in Grafana.
I did see a possible solution, but it requires manually adjusting each panel and that is not an efficient way to do this…
Under the All tab > Standard Options > Display Name type ${__field.labels.__values}
