How can I show how many points there are in a series as a legend value?
Thanks.
Thanks.
It depends on what data source you’re using?
Marcus
Hi Marcus,
We are using a data source plugin own. Can we introduce any legend value through the data source plugin?
Best regards!
César Huegel
Tel: +55 51 9562-3330 | huegelcesar@gmail.com
So then I guess you could create a metric in your data source that will sum points from another metric and plot this value on a graph with a label. Otherwise define a template variable that hold the nr of points value and use this in labels/alias fields to show the count in a label.
Marcus
Thanks for the answer, but I think this is not so clear to me. I want to put a new column in the legend table. Look at the figure below.
César Huegel
That’s not supported. I thought you wanted the count of all points for a metric written to time-series database.
If you just want a count of the nr of points plotted on graph I suggest you to have a look at Grafana github repository and search in open and closed issue for your requirement. If you don’t find any similar I suggest you to create a new feature request issue there.
Marcus
