Grafana datapoints
Is there any possibility in grafana to show value on top of datapoint in graph without moving cursor to there.
Regards,
Sreenath
You can select to display the legend with Max values. You find the options under the Legend tab.
Marcus
Yes we are already doing this .please let us know is there any other around.
Regards,
SReenath
Besides that there’s no other support.
If you find this feature really helpful I would suggest you to create a feature request issue. Please make sure that there aren’t any open/closed issue already targeting this feature.
If lots of people upvotes the issue with a thumbs up emoji as reaction to the issue description we’ll consider implementing/merging a contribution.
Marcus
