Grafana v7.5.17
Create a variable to use in dashboard by trimming a prefix from another variable. There is a datasource variable which have values like X3-region1, X3-region2, X3-region3 etc. I want to create another variable which has values like region1, region2, region3 etc. How can I remove the X3 prefix from the first variable and use the values
Clone the existing variable and apply some regex to remove the prefix from the values
What happened?
I do not find a way to modify the values of the variable -
Apply regex on the variable values and modify it to use in another variable
what is the datasource of the first variable?
It’s a custom in-house datasource. Is there a way I can use the first variable value after trimming the first 3 characters in the query instead of creating a new variable?
