Version: Grafana Version: 8.0.6
I am trying to use an existing variable value that is selected from a CUSTOM variable and select a subset of the value. The custom variable has a list of 4 API names defined in Custom Options(comma separated list). I need to reference this variable’s value in another panel query. I’ll use this value to reference an AWS Synthetic Canary name. The name of the Canary is constructed using a 13 character prefix that precedes the API name. The prefix + the Application name cannot exceed 20 characters, effectively this means the API name I used cannot be > 7 characters.
I need to reference this custom variable, but I only want the first 7 characters of it.
So, if the user select “policydata” from the Custom variable’s drop-down, I need to transform the value into “policyd”.
I was hoping that I could do this in-line instead of creating a new variable. For example: {queryvariable.substring(0,6)}. I know that substring functions do not exist in Advanced Variable Format Options in Grafana yet. But I’d like to essentially only select N number of characters (in this case N=7).
What happened?
Have not yet determined if this is possible.
Nothing implemented yet. Not sure how to make this happen.
This isn’t a configuration issue. I am seeking guidance on how to truncate an existing variable value.
No.
I’ve been through the templatings guide and I can’t find out if what I’m trying to do is possible or not. This info was obtained from the Grafana support site here:
