For a very small in-house project we like to make our custom app push OpenTelemetry Metrics directly to a self-hosted Grafana cointainer (using grafana/grafana docker image) so we can see them on our dashboard. This shall replace an older solution that used “pull” metrics using GET but standardized OpenTelemetry “push” metrics. We do not need neiter Traces not Logs nor Time Series, but really just pushed single metrics. We cannot use Grafana Cloud as the network is disconnected from the internet.
Unfortunately we cannot find a simple tutorial for this, so we have a lot of “dumb” questions:
- Does the grafana/grafana docker image support OpenTelemetry Metrics natively or doe we have to install a plug in (which one) or any kind of OpenTelemetry Metrics receiver (which one)?
- How to create a data source that reads the pushed metrics?
Any help is appreciated! ![]()
