First, what does this mean in the API documentation? Alerting Provisioning HTTP API | Grafana documentation
Contact point provisioning is for Grafana-managed alerts only.
Does that mean I can’t provision contact points unless I’m on the paid tier? Or does that just mean I can’t use the provisioning export functionality in the provisioning API?
Since I can’t export the contact point I created - it appears I’m stuck with manually provisioning the contact point in my helm values.yaml. Where can I find actual documentation on what the available options are within the contactpoint.yaml file? All I can find is, “here is an example”. But how do I find the exhaustive list of all options in that yaml spec? Alerting Provisioning HTTP API | Grafana documentation
I have so many questions like:
- What types are available?
- Given the types, what options are available under that?
- What fields are required?
Where is this documentation?
