Hello dear community!
There’s no documentation or example of how to add contact points for Grafana and configure alertmanager through yaml values file (for example using grafana helm chart).
I do not known how to create contact points that will survive pod restarting and provide possibility of IaC storing.
Could you help me please?
Thanks in advance!
welcome to the
forum, @ox7a59
Please review the submission template and include more details:
What happened?
And please remember the Grafana Forum’s 3 BEST PRACTICES:
- Please post inside a subcategory
- For questions and advice, please try to use the template below
- If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
