I have embedded my Grafana dashboard in my Angular project. Now, I want to pass parameters to Grafana Dashboard from my frontend. Can anyone tell me is it possible to do so and if yes then how?
Thanks in advance!
Thanks in advance!
Hello @abhi2001agarwal,
You can reference Template Variables through the URL in order to pass parameters.
Check the online example grafana dashboard as a reference:
https://play.grafana.org/d/rUpVRdamz/dashboard-links-with-variables?orgId=1&var-app=All&var-server=All&var-interval=1h
As you can see, there are several query paramters given like “orgId”,“var-app”,“var-server” and so on. Everything with the prefix “var-” are actually dashboard template variables which you can use in your dashboard panels or queries.
