influxdb 2.7.x
grafana 10.x -
i write security data to influxdb like that:
- “sca,project=project1,version=1.1,build=10 critical=0,high=5,medium=1,low=20”
- “sca,project=project1,version=1.2,build=20 critical=0,high=2,medium=0,low=15”
- “sca,project=project2,version=0.5,build=1 critical=5,high=12,medium=0,low=5”
i try to have connected plot between 1 and 2 for high field/value and show version as legend
- How are you trying to achieve it?
from(bucket: "securite")
|> filter(fn: (r) => r["_measurement"] == "sca")
|> filter(fn: (r) => r["_field"] == "high")
|> filter(fn: (r) => r["projet"] == "${projet}")
|> group(columns: ["projet", "_field","version"])
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: "mean")
no transformation
What happened?
plot are not connected …
if i don’t group by “version”, plot are connected but i loose “version” information
monitors security metric by version like this modified screenshost
see “how” -
no -
no
