Hello every body,
I prefer tell you firstly, I’m completely new on Grafana even if my company asked me to work on.
I use Grafana v8.0.2 and I take datas from Influx bucket.
The problem is quite simple.
My flux query :
from(bucket: “bucket_dev”)
|> range(start: -1d)
|> filter(fn: (r) => r[“_measurement”] == container_version")
|> filter(fn: (r) => r[“_field”] == “X_Version”)
|> filter(fn: (r) => r[“company”] == “Y”)
|> keep(columns:[“_time”, “_value”, “serial_number”])
Give me the following result : Table with table, _time, _value, serial_number
Now I would like to have a graph like this :
But as you can see, the legend is taken in consideration the index of the table and not the serial_ number. So, I cannot see which serial_number is on which version.
This example is done by plotly plug-in but I guess it’s possible to do the same thing with TimeSeries module.
Thank you for your help in advance.
