How to manually install the grafana-clock plugin
I’m trying to install the clock plugin on a non internet-connected system. I’ve got the zip file in /var/tmp;
how do I install it? I tried unzipping it into /var/lib/grafana/plugins, but no joy.
tried with the cli, and instead of http://… I used file:///kvar/tmp/grafana-clock…
No joy - it doesn’t underatand the file: protocol.
In both cases, I restarted grafana-server.
This is grafana 5 (latest version), on rhel 6.7
Thanks!
Graham
Please see installing plugins manually documentation.
Marcus
I did - that’s where I got the idea of using a local url. Sorry, but it’s not especially clear (to me at least). I unzipped the file into the plugins directory and restarted Grafana-server each time - but no joy.
Thanks
Permissions. Nitwit! (me)
Thanks
Graham
hi @grahamnicholls
Cant find my grafana folder under /var/lib/. This being a office machine we installed it on a desktop for trial purpose, so does the default location of the plugin folder change?
and I am facing the same issue. Can you please elaborate on what do you mean by permissions issue?
Thanks
I’m sorry, but I simply don’t remember. Assuming you’re running Linux, try
$ sudo find / -iname “grafana” -print
perhaps?
I suspect that I’d made the directory as root and not changed the ownership to the grafana user. Sorry, if by “desktop” you mean Windows, I can’t help.
Graham
Thanks Graham.
But I am not on the sudoers list to use that command. But, I think I have 2 folders where plugins are present
  1. …/grafana/data/plugins/ and this is what is listed when we try and start the Grafana like below
INFO[02-04|13:54:37] Starting Grafana                         logger=server version=5.4.3 commit=6539180 branch=HEAD compiled=2019-01-14T09:26:26-0500
INFO[02-04|13:54:37] Config loaded from                       logger=settings file=...grafana/grafana/grafana-5.4.3/conf/defaults.ini
INFO[02-04|13:54:37] Config loaded from                       logger=settings file=..../grafana/grafana/grafana-5.4.3/conf/custom.ini
INFO[02-04|13:54:37] Path Home                                logger=settings path=...../grafana/grafana/grafana-5.4.3
INFO[02-04|13:54:37] Path Data                                logger=settings path=/..../grafana/grafana/grafana-5.4.3/data
INFO[02-04|13:54:37] Path Logs                                logger=settings path=/...../grafana/grafana/grafana-5.4.3/data/log
INFO[02-04|13:54:37] Path Plugins                             logger=settings path=/....../grafana/grafana/grafana-5.4.3/data/plugins
INFO[02-04|13:54:37] Path Provisioning                        logger=settings path=/....../grafana/grafana/grafana-5.4.3/conf/provisioning
So I am assuming ..../grafana/data/plugins/ is the plugin directory. So i unzipped the downloaded plugin zip here
But at the same time i also found that there is another folder where I can see all the installed default plugins and that is ..../grafana-5.4.3/public/app/plugins/datasource/ like in the below picture:
So, assuming this is the place where all the plugins are present, I tried to unzip here as well but even that does not work
So I am at a place where i am not sure what else can I try
Please look at my other doubt here: Druid plugin manual installation
leads are very much appreciatedd
Thanks
I think, I got the plugin folder
in the conf file it says that the plugin folder is:
...../data/plugins/
cat /....../grafana/grafana/grafana-5.4.3/conf/defaults.ini | grep -i plugin
# Directory where grafana will automatically scan and look for plugins
plugins = data/plugins
# for new versions (grafana itself and plugins), check is used
# in some UI views to notify that grafana or plugin update exists
So the plugin has to be unzipped to this folder ..../data/plugins/ , so the next issue is this:
please help
Thanks
