Hi everyone
I am new to the Grafana and Druid community.
as I am being all the fire walls, cannot use the grafana-cli commands to install the Druid plugin. So, I downloaded the zip file and unzipped it under
/grafana/data/plugins/
The reason I have unzipped in that folder is that my installation is not in the default location.
Now ones I unzip, I am facing the following error ones I restart the grafana-server
/grafana/grafana/grafana-5.4.3/data/plugins/druid/dist/plugin.json, err: Plugin with same id already exists
I looked at this link https://github.com/grafana/simple-json-datasource/issues/38 and realized that the Gruntfile has to be modified.
Can you please help me on how to do that or is there any other way I can proceed and make the Druid plugin work for me
I am using Grafana 5.x.x
Thanks
