Error installing JSON datasource plugin
I am trying to install json datasource plugin, manually as the is firewall that prevents installing directly.
grafana is installed under windows.
getting this error:
Plugin Error
(SystemJS) XHR error (404 Not Found) loading http://localhost:8081/public/traceur?bust=1502095718794
Error: XHR error (404 Not Found)
Error loading http://localhost:8081/public/traceur
Unable to load transpiler to transpile http://localhost:8081/public/app/plugins/datasource/grafana-simple-json-datasource/module.js
Error loading http://localhost:8081/public/app/plugins/datasource/grafana-simple-json-datasource/module.js
How did you install it manually? Did you download the zip file from grafana.com and extract it into the data/plugins directory?
Link to zip file: https://grafana.com/api/plugins/grafana-simple-json-datasource/versions/1.3.4/download
I unzipped the zip, and copied content of src folder into:
…\public\app\plugins\datasource\
Where did you find instructions to do that? (Do we have incorrect documentation somewhere?)
From the installation page:
You should unpack the whole zip file. The src subdirectory contains the unbuilt source and will not work.
Issue solved, after coping correctly.
thanks
Hi ,
can i know the path where the simpleJson plugin was placed .
because even i am facing same issue .
It’s placed in your plugins directory. What error are you getting in the Grafana server logs? And what OS have you installed Grafana on?
Hi Daniellee,
i have installed in linux server .
in path grafana/data/plugins/simple-json
but its not reflecting in the grafana
Hi Yevsh,
can i know how did you solve the problem ?
i am using linux OS
@rashmisaravanan can you search the grafana server logs for an error, please. When you restart Grafana, there will be an error if it failed to load the plugin.
I resolved the issue :grinning:
Thanks for the reply :slight_smile:
Hi Daniellee,
Error :
customer_historic plugin failed
Error: Fetch error: 404 Not Found Instantiating http://zld05099.vci.att.com:3001/public/plugins/grafana-simple-json-datasource/module.js Loading plugins/grafana-simple-json-datasource/module
I am facing problem in installing new plugin in linux ,
i dont have internet access for the server , so i have manually downloaded and placed in
/opt/app/workload/deployments/data/grafana/plugins/plugins
same path is mentioned in custom.ini and default.ini
Regards,
Rashmi
still its throwing error
The last part of the path looks wrong. I would guess (without seeing your config file) that the path for the simple json plugin should be:
/opt/app/workload/deployments/data/grafana/plugins/grafana-simple-json-datasource
How did you install Grafana? The default for Ubuntu/Debian is that the plugin directory is located at: /var/lib/grafana/plugins
