How to limit tooltip output?
Hello everyone,
when I hover over a data point a tooltip is being displayed:
But sometimes it shows way too much data and I don’t need that.
Is there any way to customise and limit what will be displayed in the tooltip ?
Does anybody know the answer ? Any hint how to do that ?
Welcome
What is your data source? And what version of grafana are you using?
Prometheus is the data source and I am using Grafana 9.1.6
Hi @przemolb,
Welcome to the :grafana: community support forums !!
Yes, you can do that by using the Override function.
I attached a screencast (open it in a new window as will be easier to zoom in and view more clearly)
override
I hope this helps.
