Hi, all, I’m trying to figure out how to format the tooltip in a Grafana dashboard to make it either smaller or larger/longer to accommodate the embedded fields. In the example below, is there an easy to way to re-format the tooltip? Does this need to be done in the Dashboard or panel settings?
I feel this should be a simple fix but I just don’t see it, any assistance is appreciated.
