I want to see only annotation details remaining value string, source url, silence url, Dashboard url and panel url hide in the ms team alert notification?
what version grafana and are you using legacy alerting or the new Unified Alerting platform?
Grafana CLI version 9.0.2
I suppose the fitting documentation is Create and edit message templates | Grafana documentation
They can also be provisioned Create and manage alerting resources using file provisioning | Grafana documentation
You can find the default template here if you only want to remove parts of it in your custom template: grafana/default_template.go at main · grafana/grafana (github.com)
And to be complete you’ll find this answer here useful when adding templates to your contact-points: How To Use Alert Message Templates in Grafana - #3 by melori.arellano
