Grafana alert with only needed information
Hi All,
while getting slack message from Grafana dashboard. we get many information as below and we dont need that many. Is there a way to disable the below and we need to show the output of a query with a custom message that says the count is exceeding and the value is “output from query”
[FIRING:1] MyAlert (No Miss Alert)
FiringValue: [no value]
Labels:
  • alertname = myalert
  • grafana_folder = Myalert
  • rulename = No Miss
    Annotations:
    Source: link.
    Silence: link
    Dashboard: link
    Panel: link
hello @fetolicij
the default notification template you made reference to can be substituted by your own customized notifications. Check out the following docs:
