Grafana 8 Alert notifications comes with too much detailed text!
The new Grafana 8 unified alerting settings are quite harsh to get used to … most I got … but the notifications are now too technical and I found no way to toggle off the many text “junk” that comes along (like alertname, instance, etc).
I just needed the description part.
We are designing alert notifications for a not-so-technical team to keep updated with any deviance of their data showed on Grafana … the legacy alerting system worked just fine!
Found nothing here nor online on how to toggle off the details … I would apreciate any help.
Thanks.
I agree. Just created one for discord. But check this out, it might help customize and prettify your alerts
C:\Program Files\grafana-8.5.2\data\alerting\1
in there is an alert template: default.tmpl
There is this also about creating custom templates you can use for alerts
https://grafana.com/docs/grafana/latest/alerting/unified-alerting/message-templating/
Hello yosiasz, thanks for the reply,
We are using Grafana as a kubernetes pod, I couldn’t find the path nor the default.tmpl file.
Do you have any idea where is located on the Linux version?
Thanks
