How to get the whole database sql of v9.2.3?
    version: v9.2.3
    run in docker
    I want to get the whole mysql database sql of v9.2.3
  • What happened?
    I restart the grafana docker,the logs show "id=“add index dashboard.account_id” error=“Error 1072: Key column ‘account_id’ doesn’t exist in table”
    but the database is using for a lone time
    get the sql,and modify the structure of database
