HI guys i am new to grafana monitoring system. What i am trying to do is to get the ip address and hostname of the specific host when alert triggers.
I am using grafana 8.0.2 with Influxdb and telegraf. And for notification is Slack.
I getting notifications but with the message what wrote in alert section.
Please help me out.
Many Thanks.
Hi @syedusamasubzwari
I think you have a syntax issue in your message. Templated labels should go inside {{ handlebars }}:
I set up the alert template like this:
But I get it in telegram like this:
templates do not work.
what am I doing wrong?
Grafana v8.0.6 (68fe9e3431)
In defaults.ini:
[feature_toggles]
enable = ngalert
@belanchuk are you using the Classic Condition in Grafana 8 alerts? If so you won’t have the labels available to you. You’ll need to create a multi-dimensional rule
Clear, i will try, thanks!
