How to extract multiple values from a single line by delimiter
Hi Experts ,
i have table view where all alerts are consolidate with different monitor information.
one of the monitor alerts is to collect folder information path.
when there is more then one folder path it separate by @ delimiter in one string
can i use grafana to create new line in table panel something like that
from : c:\test\my file\archive@c:\test\my file\Doom@c:\test\my file\FB@c:\test\my file\Cts
to
@c:\test\my file\FB
    version 9.3
    How to extract multiple values from a single line by delimiter “@”
    transformation
  • What happened?
    im not able to do it
    from single string every time delimiter @ is there to brake the line to next one
