Split Column into multiple columns
  • What Grafana version and what operating system are you using? 10.0.1
I am new to Grafana and I am using a POSTGRES DB as the data source. Within the POSTGRES DB, there is a table with a column named “distName” that I would like to split into multiple columns using the delimiter “/”.
Below is an example of the “distName” column:
distName
/BTS/BTS/LNBTS-1000/LNCEL-1/LTE1309a
/BTS/BTS/LNBTS-2000/LNCEL-1/LTE1200a
/BTS/BTS/LNBTS-3000/LNCEL-3/LTE1800a
I want to split the “distName” column into five columns: distName1, distName2, Node, Cell, and ID.
I looked at the Transformation, but not able to figure out a way to split the columns.
  • What happened?
Will this data always be the same number of 5 columns?
SELECT split_part(distName, '/', 1) AS col1
     , split_part(distName, '/', 2) AS col2
     , split_part(distName, '/', 3) AS col3
     , split_part(distName, '/', 4) AS col4
FROM   tbl;
Thank you for your help.
I changed your input to below to get the query I want
SELECT
REVERSE(SPLIT_PART(REVERSE(“distName”), ‘/’, 1)) AS id,
REVERSE(SPLIT_PART(REVERSE(“distName”), ‘/’, 2)) AS Cell,
REVERSE(SPLIT_PART(REVERSE(“distName”), ‘/’, 3)) AS eNodeB,
REVERSE(SPLIT_PART(REVERSE(“distName”), ‘/’, 4)) AS Node
Thank you!
