8.4.0.beta1, I installed a Grafana docker container and am running a web browser pointing to the container. -
Edit the title of my panel -
I am following the tutorial. It helped me create a panel to show a random walk thingy. In the dashboard and editor I see “Panel Title”. There are no options I can see directly to change it. I later found I could go deep in the menus and found something called Panel JSON that had a title in it. But that seems like way to much knowledge needed to do something trivial. -
What happened?
Cannot easily change the title of a panel. -
Easily be able to change the title of the panel, with a click of a button. -
huh? -
There are no errors on the screen, just no ability to change the panel title. -
This is the tutorial I followed: Build your first dashboard | Grafana documentation
I am on Step 3.
I am not allowed to put more then two links so I cannot put the links to the docker installation instructions that I used, nor the somewhat similar article I found here, but was of no help.
Screenshot of my screen
OH I chose the tag “query-help” because it requires 2 tags, and I could not find any tags that even remotely helped.
