version 10.4 and linux -
I want to edit ‘Field not found’ in element of canvas panel to ‘insert field’ -
I am editing the metricValue.tsx code in /usr/share/grafana/public/app/features/canvas/elements -
What happened?
The changes that i made in the code is not visible on the browser -
I expect ‘Field not found’ to change to ‘insert field’ -
You need to change that text in file /usr/share/grafana/public/build/canvasPanel.XXXXXX.js file (XXXXXX depends from Grafana version, i.e. canvasPanel.a46aa5e57d26b1fcc380.js):
