Extending Grafana Canvas Visualization Functionality
Hello everyone, how can I extend the functionality of the Grafana canvas visualization? I need to add a feature to the metricValue element that, when an item is selected, displays the data of that selected item both in a table and on a graph within a modal window. How can this be implemented?
The code of the metricValue.tsx file (grafana/public/app/features/canvas/elements/metricValue.tsx at main · grafana/grafana · GitHub):
import { css } from '@emotion/css';
import { useCallback } from 'react';
import { useObservable } from 'react-use';
import { of } from 'rxjs';
import {
  DataFrame,
  FieldNamePickerConfigSettings,
  GrafanaTheme2,
  OneClickMode,
  StandardEditorsRegistryItem,
} from '@grafana/data';
import { TextDimensionMode } from '@grafana/schema';
import { usePanelContext, useStyles2 } from '@grafana/ui';
import { FieldNamePicker } from '@grafana/ui/src/components/MatchersUI/FieldNamePicker';
import { frameHasName, getFrameFieldsDisplayNames } from '@grafana/ui/src/components/MatchersUI/utils';
import { DimensionContext } from 'app/features/dimensions/context';
import { ColorDimensionEditor } from 'app/features/dimensions/editors/ColorDimensionEditor';
import { TextDimensionEditor } from 'app/features/dimensions/editors/TextDimensionEditor';
import {
  CanvasElementItem,
  CanvasElementOptions,
  CanvasElementProps,
  defaultBgColor,
  defaultTextColor,
} from '../element';
import { ElementState } from '../runtime/element';
import { Align, TextConfig, TextData, VAlign } from '../types';
// eslint-disable-next-line
const dummyFieldSettings: StandardEditorsRegistryItem<string, FieldNamePickerConfigSettings> = {
  settings: {},
} as StandardEditorsRegistryItem<string, FieldNamePickerConfigSettings>;
const MetricValueDisplay = (props: CanvasElementProps<TextConfig, TextData>) => {
  const { data, isSelected, config } = props;
  const styles = useStyles2(getStyles(data));
  const context = usePanelContext();
  const scene = context.instanceState?.scene;
  let panelData: DataFrame[];
  panelData = context.instanceState?.scene?.data.series;
  const isEditMode = useObservable<boolean>(scene?.editModeEnabled ?? of(false));
  const getDisplayValue = () => {
    if (panelData && config.text?.field && fieldNotFound()) {
      return 'Field not found';
    if (panelData && config.text?.field && !data?.text) {
      return 'No data';
    return data?.text ? data.text : 'Double click to set field';
  const fieldNotFound = () => {
    const fieldNames = getFrameFieldsDisplayNames(panelData);
    return !frameHasName(config.text?.field, fieldNames);
  if (isEditMode && isSelected) {
    return <MetricValueEdit {...props} />;
  return (
    <div className={styles.container}>
      <span className={styles.span}>{getDisplayValue()}</span>
    </div>
const MetricValueEdit = (props: CanvasElementProps<TextConfig, TextData>) => {
  let { data, config } = props;
  const onFieldChange = useCallback(
    (field: string | undefined) => {
      let selectedElement: ElementState;
      selectedElement = context.instanceState?.selected[0];
      if (selectedElement) {
        const options = selectedElement.options;
        selectedElement.onChange({
          ...options,
          config: {
            ...options.config,
            text: { fixed: '', field: field, mode: TextDimensionMode.Field },
          background: {
            color: { field: field, fixed: options.background?.color?.fixed ?? '' },
        // Force a re-render (update scene data after config update)
        if (scene) {
          scene.editModeEnabled.next(false);
          scene.updateData(scene.data);
    [context.instanceState?.scene, context.instanceState?.selected]
  return (
    <div className={styles.inlineEditorContainer}>
      {panelData && (
        <FieldNamePicker
          context={{ data: panelData }}
          value={config.text?.field ?? ''}
          onChange={onFieldChange}
          item={dummyFieldSettings}
    </div>
const getStyles = (data: TextData | undefined) => (theme: GrafanaTheme2) => ({
  container: css({
    position: 'absolute',
    height: '100%',
    width: '100%',
    display: 'table',
  inlineEditorContainer: css({
    height: '100%',
    width: '100%',
    display: 'flex',
    alignItems: 'center',
    padding: theme.spacing(1),
  span: css({
    display: 'table-cell',
    verticalAlign: data?.valign,
    textAlign: data?.align,
    fontSize: `${data?.size}px`,
    color: data?.color,
export const metricValueItem: CanvasElementItem<TextConfig, TextData> = {
  description: 'Display a field value',
  display: MetricValueDisplay,
  hasEditMode: true,
  defaultSize: {
    width: 260,
    height: 50,
  getNewOptions: (options) => ({
    ...options,
    config: {
      align: Align.Center,
      valign: VAlign.Middle,
      color: {
        fixed: defaultTextColor,
      text: { mode: TextDimensionMode.Field, fixed: '', field: '' },
    background: {
      color: {
        fixed: defaultBgColor,
    placement: {
      width: options?.placement?.width,
      height: options?.placement?.height,
      top: options?.placement?.top ?? 100,
      left: options?.placement?.left ?? 100,
      rotation: options?.placement?.rotation ?? 0,
    oneClickMode: options?.oneClickMode ?? OneClickMode.Off,
    links: options?.links ?? [],
  prepareData: (dimensionContext: DimensionContext, elementOptions: CanvasElementOptions<TextConfig>) => {
    const textConfig = elementOptions.config;
    const data: TextData = {
      text: textConfig?.text ? dimensionContext.getText(textConfig.text).value() : '',
      field: textConfig?.text?.field,
      align: textConfig?.align ?? Align.Center,
      valign: textConfig?.valign ?? VAlign.Middle,
    if (textConfig?.color) {
      data.color = dimensionContext.getColor(textConfig.color).value();
    return data;
  registerOptionsUI: (builder) => {
    const category = ['Metric value'];
    builder
      .addCustomEditor({
        category,
        path: 'config.text',
        editor: TextDimensionEditor,
      .addCustomEditor({
        category,
        path: 'config.color',
        editor: ColorDimensionEditor,
        settings: {},
        defaultValue: {},
      .addRadio({
        category,
        path: 'config.align',
        settings: {
          options: [
            { value: Align.Left, label: 'Left' },
            { value: Align.Center, label: 'Center' },
            { value: Align.Right, label: 'Right' },
        defaultValue: Align.Left,
      .addRadio({
        category,
        path: 'config.valign',
        settings: {
          options: [
            { value: VAlign.Top, label: 'Top' },
            { value: VAlign.Middle, label: 'Middle' },
            { value: VAlign.Bottom, label: 'Bottom' },
        defaultValue: VAlign.Middle,
      .addNumberInput({
        category,
        path: 'config.size',
        settings: {
          placeholder: 'Auto',
hi @maxymzakharkiv you can not extend panels like this, what you can do is open a pull request in the grafana/grafana repository with the functionality you desire.
You want to first read the Grafana contribution guide
So, new elements for canvas visualization can be added as shown in this article (Pizzeria observability on Grafana Canvas panel | Volkov Labs), but existing elements cannot be modified to suit specific needs. Did I understand you correctly?
