How to edit chart settings in the explore tab?
I want to make a quick chart of some metrics so I used the explore tab. However the graphs are not quite what I want, I need to edit the ranges and add labels. Can I do that from the explore tab, or do I have to create a new panel each time?
Hi @vladimir15!
As you can see in the official documentation, Explore is only for analyzing queries not for creating panels and dashboards, so you need to use Dashboard/Panel to edit the ranges and add labels.
