How to do a localinstall of rpm and start Grafana from a specific path?
    grafana-9.1.5-1.x86_64 & RHEL 7.9
    Trying to install Grafana on a data disk instead of OS disk. But not able to start Grafana Seems i need to add some links to service file.
Need some guidanc eon this.
    yum localinstall .rpm --rootinstall=path
  • What happened?
    it installs all libs/var etc to the given path. But when i try systemd start the system cant find the service file.
Hi @dpclix,
Did you try something like
systemctl start grafana-server
then verify the status via:
systemctl status grafana-server
Also, if not then please check this documentation link for RHEL distributions:
I hope this helps.
