hello,
i try to install grafana.
I followed the tutorial but i don’t understand step
" The grafana-server binary needs the working directory to be the root install directory where the binary and the public folder are located.
Start Grafana by running:
./bin/grafana-server web
I don't have grafana directory in "/bin". I have only file grafana-server or -cli in /usr/sbin
i using redhat enterprise 8.3
can u help me please ?
Thks
Hello, the instructions to install Grafana on RHEL is here: Install on RPM-based Linux | Grafana Labs and the download page is: Download Grafana | Grafana Labs
Let us know if these topics help you solve the issues.
Thank you.
hello,
thanks for reply.
i know your link and i followed this
i have problems with the end of tutorial install
in the page’s bottom
Did you install using :
sudo yum install grafana
In this case you should use systemctl, otherwise if you used the tar file, you will find a bin directory with grafana-server inside the extracted package.
Hope it helps.
Good Luck
ok i didnt understand that. Yes i used yum (in sudo user) and systemctl
but i cant acces [serveripadress:3000]
i opened 3000 port in firewall
What does
curl community.grafana.com
return?
Found
In fact i didn’t started grafane-server
sorry sorry sorry
But i can’t “enable”
update-rc.d: error: no runlevel symlinks to modify, aborting!
