Is there a way to attach process on a grafana backend plugin ?
I tried building the plugin with some args then attaching to a process with pid with dvl but no use… it just throws some errors!
I know the plugin is communicating with grafana through grpc… how can we achieve such thing ?
Well… after some struggle I managed…
All I did was installing this package
go get -t github.com/google/gops/
Then adding gcflags argument to the plugin build command.
go build -gcflags="all=-N -l" -o ./dist/gpx_plugin-datasource_windows_amd64.exe ./pkg
Subsequently with Goland attach to process and we good
