Backend Datasource React Plugin
@marcusolsson
@torkel
  1. Is the ‘ backend plugin ’ mandatory in order to communicate with the server from which the data is fetched ?
    -or- can any code be executed in the query method in DataSource.ts ?
  2. Must the backend plugin be written in GO ?
  3. Following the example in:
    https://github.com/marcusolsson/grafana-csv-datasource/blob/master/docs/adding-datasource-backend.md - Grafana server fails to init the plugin:
C:\Grafana\grafana-6.4.0-beta1\data\plugins\csv-datasource\dist/csv-
datasource_windows_amd64.exe": file does not exist
The exe file does exist no disk, but I am on Windows so it seems the separating character should be changed. What file is responsible for that ? where should I change ?
  1. You don’t need a backend plugin to write a data source. The data source plugin can communicate directly with your database.
  2. For now, we only support Go
  3. I’m not sure we’re this is defined. I’ll see if I can look it up!
