How to create table with Sparkline
    Version 9.5.20
    To create sparkline cells in my table
    By field override the column with the value
  • What happened?
    On all of the cells of column value, It says: no data
    See sparkline graph
    Only finding articles that sparklines exist. There is not written how to create them and start using them
