Grafana: 9.4.7
OS: Windows 10
- What are you trying to achieve?
I am trying to enable the Sparkline in table feature
- How are you trying to achieve it?
Added the following to default.ini configuration file:
# Enable timeseries spark line for table
timeSeriesTable = true
- What happened?
I don’t see the new cell type override available to be selected.
I expected there to be a new Sparkline option available when selecting a cell type override.
- Can you copy/paste the configuration(s) that you are having problems with?
As above.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No
- Did you follow any online instructions? If so, what is the URL?
