Transformations time series to table show json frame
  • Grafana v12.0.0 (4c0e7045f9)
  • Display HTTP client availability metrics in a table view.
  • Using a Prometheus query availability like this:
  • sum(rate(traces_span_metrics_duration_seconds_count{service_name=“service-message-platform”, component=“httpclient”, status_code=~“OK|STATUS_CODE_UNSET”}[1m])) by (server_address, server_port, span_name) / sum(rate(traces_span_metrics_duration_seconds_count{service_name=“service-message-platform”, component=“httpclient”}[1m])) by (server_address, server_port, span_name)
  • What happened?
  • one of those metrics empty will make table show json frame
  • show availability = 0% if empty status_code=~“OK|STATUS_CODE_UNSET” metrics
Hi, setting Cell type → Sparkline in overrides for this column should help. (I guess type Autodoesn’t recognise it as sparkline when some cells don’t have the data).
It works, many thanks.
