How to Clear Grafana Pending Alert
The Alert Notification value for a CPU Util % has been met and shoult have triggered a notification, but no notification email was sent. In the Alerts section I only find an entry for the target system that indicates the CPU Util % has been in Pending for 5 days which is when the Dashboard was created. Performing a test on the Alert condition for the CPU Util % returns false. Why is the Pending status not cleared? Is there a way to manually clear it?
Test Output:
firing:false
state:""
conditionEvals:“false = false”
timeMs:“32.097ms”
logs:Array[4]
0:Object
message:“Condition[0]: Query Result”
data:Array[3]
1:Object
message:“Condition[0]: Eval: false, Metric: CPUUtilization_Average, Value: null”
data:null
2:Object
message:“Condition[0]: Eval: false, Metric: CPUUtilization_Maximum, Value: null”
data:null
3:Object
message:“Condition[0]: Eval: false, Metric: CPUUtilization_Minimum, Value: null”
data:null
Could it be because there is no value received?
It says “Condition[0]” on all 3 objects, is that correct?
Thanks for jumping in. I’ve just started using Grafana last week. I setup about 10 Dashboards based on CloudWatch datafeeds with 5 Panels each and Alerts/Notifications on each. This is the only metric that is having this trouble.
The Alert test does show Condition[0], but the chart for the metric shows data coming consistently.
We got a notification from CloudWatch, but nothing from Grafana. Not sure how to resolve this.
I tried dropping the Panel and recreating it. Still have the same issue with the test output. The Alert section still shows it has been in that state for 5 days.
