hi ,
I got following error when I using oauth ,is there any method to change the client authentication method? thanks
error message:
401 Unauthorized\nResponse: {“error”:“invalid_client”,“error_description”:“Client authentication failed (e.g., unknown client, no client authentication included, or unsupported authentication method)”,“error_hint”:“The OAuth 2.0 Client supports client authentication method \“none\”, but method \“client_secret_post\” was requested. You must configure the OAuth 2.0 client’s \“token_endpoint_auth_method\” value to accept \“client_secret_post\”.”,“status_code”:401}"
