Openshift - Generic Oauth?
Hello everyone,
I am currently experiencing some troubles connecting a grafana instance deployed on openshift origin to the built-in oauth-provider of openshift (Everything except the oauth works for me).
What I did:
  • created an OAuthClient in OpenShift with:
oc create -f <(echo '
> kind: OAuthClient
> apiVersion: v1
> metadata:
> secret: grafana
> redirectURIs:
>  - "https://grafana.localhost/login/generic_oauth"
> grantMethod: prompt
  • added these lines to the grafana.ini:
[auth.generic_oauth]
enabled=true
client_id=grafana
client_secret=grafana
scopes= user:full, user:check-access
auth_url=https://10.0.2.15:8443/oauth/authorize
token_url=https://10.0.2.15:8443/oauth/token
api_url= https://10.0.2.15:8443/oapi/v1/users/
allowed_domains=
allow_sign_up=true
, deployed grafana to openshift and try to log in. I get this error message, but I don’t know what to make of it really:
{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","state":"tacgvvNlx3IsSZjrHzul3x2jE7HOM2wePXX3QjFF/34="}
Has anyone of you ever connected grafana to the openshift oauth? Would really appreciate any suggestions.
Best regards
kkraemer
don’t know, seems openshift’s oauth implementation is not supported, dont have access to one to test with :frowning:
i do it the same way and i will redirected to the login screen of openshift. But after this, there is a problem for grafana to fetch the right informationen:
t=2017-10-09T15:00:05+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/ status=302 remote_addr=10.180.47.0 time_ms=0 size=29 referer=
t=2017-10-09T15:00:12+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=302 remote_addr=10.180.47.0 time_ms=0 size=299 referer=https://10.104.104.135:3000/login
t=2017-10-09T15:00:21+0000 lvl=eror msg=“login.OAuthLogin(get info from generic_oauth)” logger=context userId=0 orgId=0 uname= error="Error getting user info: {\n “kind”: “Status”,\n “apiVersion”: “v1”,\n “metadata”: {},\n “status”: “Failure”,\n “message”: “scopes [user:info] prevent this action; User \“HolgerKoch\” cannot list all users in the cluster”,\n “reason”: “Forbidden”,\n “details”: {\n “kind”: “users”\n },\n “code”: 403\n}\n"
t=2017-10-09T15:00:21+0000 lvl=eror msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=10.180.47.0 time_ms=118 size=703 referer=“https://console.inet-abnahme.ose.db.de/login?then=%2Foauth%2Fauthorize%3Faccess_type%3Donline%26client_id%3Dgrafana%26redirect_uri%3Dhttps%3A%2F%2F10.104.104.135%3A3000%2Flogin%2Fgeneric_oauth%26response_type%3Dcode%26scope%3Duser%3Ainfo%26state%3DhvZGugvSncELjo3WzhGr5N1zw6R7A1kSPT49%2FhPQv0Y%3D
did you solve the problem? Or did anybody have a hint for me?
best regards
Holger
