Version 7.4.5 (commit: 8a2c78d3f8, branch: HEAD) -
oauth using generic_oauth
- How are you trying to achieve it?
running container in k8s
- What happened?
the oauth flow works as desired via kubectl port-forward $POD 3000
and then using http://grafana.staged-by-discourse.com in the browser.
However when i try to use the same flow via configured DNS to the ingress, I successfully reach the service and am redirected to /login …but that does NOT show ‘or use oauth’ button.
I am at a loss why the browser UX decides to not show the oauth option.
The ‘or login with oauth’ checkbox appears and i can proceed to login via oauth.
auth.generic_oauth: allow_signup: true allowed_domains: example.org api_url: https://hello.example.org/auth/realms/mine/protocol/openid-connect/userinfo auth_url: https://hello.example.org/auth/realms/mine/protocol/openid-connect/auth client_id: grafana-dev client_secret: readacted... enabled: true name: generic_oauth scopes: openid email profile tls_skip_verify_insecure: false token_url: https://hello.example.org/auth/realms/mine/protocol/openid-connect/token
no errors in UI nor in logs. Note: logs on grafana were configured to debug.
- Did you follow any online instructions? If so, what is the URL?
